Glenn Quesenberry Wed, 09/02/2009 - 12:59
Yes!  Disconnecting the fan would not only cause the unit to overheat and fail but would also void any warranty you have the product.  There is a Cisco Small Business Managed Switch that is fanless and thus makes no noise, but it's only an 8-port switch.  Is a 24-port switch a requirement for your home use?  If not, take a look at the SFE1000P.
