UCS:Cannot Invoke Create vNIC form when double clicked on a VLAN.
Sep 2nd, 2009
In order to add a new VNIC is to double-click one of the VLAN's defined
on the system. This should automatically bring up a form that one could use to create a new vNIC attached to that VLAN.
Not sure why I cannot perform this operation? Is it a privilege/permission that I do not have? I am logged in as admin.
cco-iamrodos Tue, 09/15/2009 - 18:36
Which screen are you looking at when you are clicking on the vLAN?
A vNIC is associated with a service profile. If you go to a service profile, then go to the vNICs tab, then use the [+]Add button at the bottom to add another vNIC. You can then pick which vLAN you want on that vNIC, or you can enable trunking and device which vLANs you want to pass down the trunk. You can also [Crate VLAN] from there as well.
Rodos
