09-02-2009 11:42 AM
Dear friends,
When I tried to simulate the ATM network for Ammavan Thomas regarding his question here about the MPLS over PPP over ATM I came across a strange problem.
I was experimenting with two IOS versions for 7200 series on dynamips. I have used the same topology - two routers connected back to back using their ATM1/0 interface.
I have used the following configuration:
R1:
interface ATM1/0
no ip address
no atm ilmi-keepalive
interface ATM1/0.1 point-to-point
no snmp trap link-status
pvc 0/61
encapsulation aal5snap
protocol ppp Virtual-Template1
interface Virtual-Template1
ip address 10.0.0.1 255.255.255.0
On R2:
interface ATM1/0
no ip address
pvc 0/61
ip address 10.0.0.2 255.255.255.0
Now, when I use this configuration on IOS 12.3, everything works just fine and there is full IP connectivity between the two routers. The show ip interface brief on R1 shows this:
R1#show ip int brief
FastEthernet0/0 unassigned YES unset administratively down down
ATM1/0 unassigned YES manual up up
ATM1/0.1 unassigned YES unset up up
Virtual-Access1 unassigned YES unset up up
Virtual-Access1.1 10.0.0.1 YES TFTP up up
Virtual-Template1 10.0.0.1 YES manual down down
Virtual-Access2 unassigned YES unset down down
However, when I apply the very same configuration on IOS 12.4, there are problems. Note the show ip interface brief on R1 again:
Virtual-Access1 unassigned YES unset down down
Note that the interface Virtual-Access1 remains down/down. The interfaces Virtual-Access1.1 and Virtual-Access2 are not created at all. The PPP negotiation never takes place. Simply - the PPP session never comes up.
Is there anything that should be configured differently on the 12.4 version? Am I doing any mistake here? Any hint or suggestion is greatly appreciated!
Best regards,
Peter
09-24-2009 02:16 PM
Hi.. I have a Cisco 877 (ADSL Interface) and we work ADSL Technology.. atach the following.
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/81
pppoe-client dial-pool-number 1
the PVC es may possible 8/35 or 8/81.. this number was given by the carrier mode bridge or router depends of the service..
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip virtual-reassembly
encapsulation ppp
no ip route-cache cef
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no fair-queue
down-when-looped
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxx password xxx
crypto map xxx
ATM0 unassigned YES NVRAM up up
ATM0.1 unassigned YES unset up up
Vlan1 100.2.225.1 YES NVRAM up up
Dialer0 xxx.xxx.xxx.xxx YES IPCP up up
the carrier is infinitum (Telmex)
