Telnet Problem
Sep 2nd, 2009
I am having an issue telneting from any device on my network to a 4503 (running Version 12.2(31)SG).
The following is the configuration for the vty lines:
line vty 0 4
exec-timeout 5 0
login local
transport input all
transport output telnet
line vty 5 15
exec-timeout 5 0
login local
transport input all
The following is what I get on a debug:
Sep 2 19:47:41 UTC: Telnet1: 1 1 251 1
Sep 2 19:47:41 UTC: TCP1: Telnet sent WILL ECHO (1)
Sep 2 19:47:41 UTC: Telnet1: 2 2 251 3
Sep 2 19:47:41 UTC: TCP1: Telnet sent WILL SUPPRESS-GA (3)
Sep 2 19:47:41 UTC: Telnet1: 80000 80000 253 24
Sep 2 19:47:41 UTC: TCP1: Telnet sent DO TTY-TYPE (24)
Sep 2 19:47:41 UTC: Telnet1: 10000000 10000000 253 31
Sep 2 19:47:41 UTC: TCP1: Telnet sent DO WINDOW-SIZE (31)
Sep 2 19:47:41 UTC: TCP1: Telnet received DO SUPPRESS-GA (3)
Sep 2 19:47:41 UTC: TCP1: Telnet received WILL TTY-LOCATION (23) (refused)
Sep 2 19:47:41 UTC: TCP1: Telnet sent DONT TTY-LOCATION (23)
Sep 2 19:47:41 UTC: TCP1: Telnet received WILL TTY-SPEED (32) (refused)
Sep 2 19:47:41 UTC: TCP1: Telnet sent DONT TTY-SPEED (32)
Sep 2 19:47:41 UTC: TCP1: Telnet received WILL WINDOW-SIZE (31)
Sep 2 19:47:41 UTC: TCP1: Telnet received WILL LOCAL-FLOW (33) (refused)
Sep 2 19:47:41 UTC: TCP1: Telnet sent DONT LOCAL-FLOW (33)
Sep 2 19:47:41 UTC: TCP1: Telnet received DO ECHO (1)
Sep 2 19:47:41 UTC: TCP1: Telnet received WONT TTY-TYPE (24)
Sep 2 19:47:41 UTC: TCP1: Telnet sent DONT TTY-TYPE (24)
Sep 2 19:47:41 UTC: Telnet1: recv SB NAWS 80 24
Sep 2 19:47:41 UTC: TCP1: Telnet received WONT TTY-LOCATION (23)
Sep 2 19:47:41 UTC: TCP1: Telnet received WONT TTY-SPEED (32)
Sep 2 19:47:41 UTC: TCP1: Telnet received WONT LOCAL-FLOW (33)
[Connection to X.X.X.X closed by foreign host]
Thanks.
Edison Ortiz Wed, 09/02/2009 - 15:34
I don't see any ACLs under the VTY but do you have any Security ACLs on the switch preventing telnet?
If you can post a sanitized config from the switch, we can help further.
__
Edison.
keyonj Thu, 09/03/2009 - 07:42
Edison, the only other security ACLs in place are for snmp and for https access.
There are no other ACLs that I can see in the config.
one weird thing, that I did notice, that doesnt show up in the config are ACLs that appear to be for control plane policing. When I do a 'show access-lists' the following list is displayed (aside from the two ACLS that show up in the config for snmp and http):
Extended IP access list system-cpp-all-routers-on-subnet
10 permit ip any host 224.0.0.2
Extended IP access list system-cpp-all-systems-on-subnet
10 permit ip any host 224.0.0.1
Extended IP access list system-cpp-dhcp-cs
10 permit udp any eq bootpc any eq bootps
Extended IP access list system-cpp-dhcp-sc
10 permit udp any eq bootps any eq bootpc
Extended IP access list system-cpp-dhcp-ss
10 permit udp any eq bootps any eq bootps
Extended IP access list system-cpp-igmp
10 permit igmp any 224.0.0.0 31.255.255.255
Extended IP access list system-cpp-ip-mcast-linklocal
10 permit ip any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ospf
10 permit ospf any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-pim
10 permit pim any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ripv2
10 permit ip any host 224.0.0.9
Extended MAC access list system-cpp-bpdu-range
permit any 0180.c200.0000 0000.0000.000f
Extended MAC access list system-cpp-cdp
permit any host 0100.0ccc.cccc
Extended MAC access list system-cpp-cgmp
permit any host 0100.0cdd.dddd
Extended MAC access list system-cpp-dot1x
permit any host 0180.c200.0003
Extended MAC access list system-cpp-garp-range
permit any 0180.c200.0020 0000.0000.000f
Extended MAC access list system-cpp-sstp
permit any host 0100.0ccc.cccd
However, I'm not sure if its tied to anything. When I run any of the following commands, nothing is displayed.
sh policy-map system-cpp-policy
sh policy-map control-plane input
FYI, I will work on getting the sanitized config posted.
