09-02-2009 09:27 PM - edited 03-06-2019 07:33 AM
greeting
attach the sh process memory output, and can I get some advice, if I have memory problems? if so, does it cause my cat6500 process high to 90% time by time, but only few minutes or even most time few seconds?
I have client complain about connection broken time by time, but every time only have problem for few minutes. and my cat6500 use 12.2(33)SXI1. I have checked system, and logs, I can not find any problems but the memory.
Any comment will be appreciated
Thanks in advance
09-03-2009 07:31 AM
Hello Julie,
post a sh proc cpu history
sh proc cpu sorted 1min
when you say 90% do you mean cpu usage?
I agree that your device shouldn't have memory issues
sh proc mem
Processor Pool Total: 377171344 Used: 134847520 Free: 242323824
I/O Pool Total: 67108864 Used: 16487640 Free: 50621224
you still have more then 200 MB free of main memory and 50MB free for I/O operations
Hope to help
Giuseppe
09-03-2009 08:59 PM
Thanks for the reply. the sh prc cpu history is:
#sh proc cpu history
11111 11111 11111111111111111111 11111
7222228888811111999999999944444555553333355555777773333377
100
90
80
70
60
50
40
30
20 ***** *****
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
1212111161151530314383111531117521112211121326221232141211
5170584535602650383718562878733248686066643719825868415131
100 *
90 *
80 * *
70 * * * *
60 * * * * * * *
50 * * * * * * ** *
40 * * **# **#* ** ** * * * *
30 * * *##* *##* ** ** * * ** *#* *
20 ****** *#*** ####*####** ##** ##****##**** **##***## ***
10 ##########################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
7335322222222225223233340384322222222224223365553455332122222225222344
3113465210704141450394620162150631438165672762838828806925223040927718
100 *
90 * *
80 * *
70 * * * *
60 * * * * * *
50 * * * * * * **** *** * *
40 * * * * *** ** * ********** * ***
30 ******* * * ** ********** * * ***************** * ** ****
20 **********************************************************************
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
09-03-2009 09:33 PM
Hello Julie,
I think cpu usage is too high for a C6500 class device.
You may be hitting a bug or there is a configuration issue.
May you post in an attachment file
this is to see what processes are using more resources.
Other collegues have reported cases of increased cpu usage moving to 12.2(33)SXI.
Hope to help
Giuseppe
09-03-2009 09:44 PM
yes, I use 12.2(33)SXI1 currently
#sh proc cpu sorted 1min | e 0.00
CPU utilization for five seconds: 14%/8%; one minute: 22%; five minutes: 19%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
489 6739596 4474027 1506 0.95% 1.77% 2.04% 0 Syslog
340 1256212 6660908 188 0.63% 0.98% 1.02% 0 FM core
11 32735056 75304478 434 0.23% 0.68% 0.67% 0 ARP Input
447 41679060 307144374 135 1.11% 0.66% 0.59% 0 Port manager per
262 20418292 197586337 103 0.55% 0.60% 0.61% 0 IP Input
48 1649868 5134951 321 0.31% 0.48% 0.54% 0 Logger
502 23388892 21349137 1095 0.55% 0.35% 0.38% 0 SNMP ENGINE
507 15480348 57106663 271 0.15% 0.33% 0.39% 0 PIM Process
299 5845404 1057691 5526 0.23% 0.12% 0.11% 0 QOS Stats Gather
512 1039884 18721382 55 0.15% 0.06% 0.01% 0 HSRP IPv4
501 2571576 8041517 319 0.07% 0.03% 0.05% 0 PDU DISPATCHER
