%TCAMMGR-3-HANDLE_ERROR: cam handle [hex] is invalid
Sep 2nd, 2009
Hi NetPro,
Does anyone know how to solve this ? My switch 3750 down with this error msg.
your reply will be highly appreciated.
The CAM Handle used by the caller is not valid.
Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at
http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Also perform a search of the Bug Toolkit
http://www.cisco.com/pcgi-bin/Support/Bugtool/home.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet
http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support representative and provide the representative with the gathered information.
Related documents- No specific documents apply to this error message.
Overall Rating: 3 (2 ratings)
Giuseppe Larosa Thu, 09/03/2009 - 20:25
  • Hall of Fame,
    Founding Member
Hello Jack,
have you tried to reload the switch?
CAM table is a core function of lan switch so you need to understand if device is usable or not.
Hope to help
Giuseppe
ngengyeong Thu, 09/03/2009 - 20:52
Hi Giuseppe,
Yes, during that time i have no choice i can't even capture the show tech during that time as the switch is having intermittent i was forced to reboot this switch, then problem resolve , those downstream switches are up again .
but, now management need to know what is the root cause ? sigh ~~~ anyone know what is about ?
Giuseppe Larosa Thu, 09/03/2009 - 20:59
  • Hall of Fame,
    Founding Member
Hello Jack,
this is likely a software bug because it speaks of handlers.
do a search in the bug toolkit or post the version of your IOS image.
I would use TCAM as search keyword but I see I get no results
Hope to help
Giuseppe
ngengyeong Thu, 09/03/2009 - 21:08
Hi Giuseppe,
yes, but the bugs have been fixed by the newer version. my switch version is 12.2(35)SE5. shouldn't be impacted .
