Show Commands in 1131 AG AP
Sep 2nd, 2009
hi experts,
i would like to know how to verify using show commands in CLI if 1131AG AP radio is working and if clients are associating on AP
Overall Rating: 5 (1 ratings)
rob.huffman Thu, 09/03/2009 - 05:29
Hi John,
show dot11 associations
[client | repeater | statistics | H.H.H | bss-only | all-client | cckm-statistics]
This example shows how to display all client devices associated with the access point:
AP# show dot11 associations client
show controllers dot11radio
Use the show controllers dot11radio privileged EXEC command to display the radio controller status.
show controllers dot11radio interface-number
Syntax Description
Specifies the radio interface number. The 2.4-GHz radio is radio 0. The 5-GHz radio is radio 1.
Hope this helps!
Leo Laohoo Thu, 09/03/2009 - 15:43
In addtion to Rob's post (+5), I would also add show dot11 associations stat. This will give you a reading of the number of successful authentication since last counter reset (by reboot). I look at the values of cDot11AssStatsAuthenticated.
Hope this helps.
