LMS3.0.1/HUM backup failed
Sep 2nd, 2009
Customer has an error message when he makes a LMS backup:
extract from dbbackup.log :
1 error reported
Run time SQL error -- Index "Template18_5mins_TSINDEX" has invalid or duplicate index entries
Validation C:/Backup_LMS\436\upm\database\upm.db failed.
ERROR(1083): Database upm backup failed and . Check the log file for information.
Backup failed: 2009/09/02 03:50:11
Thanks for help ?
Elisabeth
Overall Rating: 4 (1 ratings)
Joe Clarke Thu, 09/03/2009 - 09:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The UPM database is corrupt. You will need to restore it from a known good backup, or reinitialize it with the command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=upm dmprefix=UPM
ebezombes Thu, 09/03/2009 - 22:55
Is it possible to restore only upm database without restoring other database like rme, campus, ut, ... ?
Joe Clarke Thu, 09/03/2009 - 22:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No. The LMS backup/restore is all or nothing.
ebezombes Thu, 09/03/2009 - 23:09
When we reinit upm.db, do we lost configuration as poller, templates and reports ? Or only data ?
Joe Clarke Fri, 09/04/2009 - 07:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You lose everything in HUM. This includes pollers, custom templates, polled data, thresholds, etc.
ebezombes Sun, 09/06/2009 - 22:51
If we open a tac case, do you think they will be able to correct this corruption database ?
Joe Clarke Mon, 09/07/2009 - 03:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No. Database corruption caanot be corrected. You can only restore from backup, or reinitialize.
paul.parquet Mon, 10/05/2009 - 07:47
Thanks, a lot. I reinitialize the database with the command NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=upm dmprefix=UPM and recreate my poller and report, and launch a backup.
All is right now.
Paul Parquet
