ASA5520: Upgrading User CompactFlash
Answered Question
Sep 3rd, 2009
Can't find a procedure describing the upgrade of Compact Flash. Do I need to back up the entire file system and copy it back to the new CompactFlash ?
Correct Answer by August Ritchie about 7 years 5 months ago
When you upgrade the flash using the expansion slot on the front, you do not need to copy anything as you are simply adding additional Compact Flash. Your original file system is still stored on the internal flash.
Now if you replace this internal flash (system flash) you need to TFTP your contents onto a TFTP server then, copy them back to the new flash.
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/guide/procs.html#wp1031632
Overall Rating: 4 (1 ratings)
Correct Answer
August Ritchie Thu, 09/03/2009 - 12:37
gdspa Wed, 07/21/2010 - 02:35
I have a couple of ASA5510 in failover, do I need to power them off before inserting the external compact flash?
