QoS on Catalyst not runnning,advise pls!
Sep 3rd, 2009
I did a ftp test.Speed i got is 25KB/S.it seems like the policy is not taking effect.Any idea?Together is the config.
class-map match-all abc
match access-group 1
policy-map vlan
class abc
police 1000000 65536 exceed-action drop
ip subnet-zero
no ip finger
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
service-policy input vlan
access-list 1 permit any
Peter Paluch Thu, 09/03/2009 - 03:18
Please go over all the following questions:
What is the type of your switch and the IOS version you are running? Is the "mls qos" command present in the configuration? Is the policy-map applied in the correct direction?
Also note that this policing limits the traffic down to 1 Mbps. You have said that the FTP speed was 25 KBytes/s. That is well under the limit that the policer imposes. Is there something wrong with it?
Best regards,
Peter
