integration with CRM
Sep 3rd, 2009
hey guys..
got a small query..
which version of CCX (Enhanced or Premium) supports integration with CRM???
do you guys have any cisco doc regarding this?
also u got some Technical docs available for CRM integration???
Fadhu
Overall Rating: 5 (1 ratings)
daljeetsingh1_2 Thu, 09/03/2009 - 04:01
Which CRM you have? & What functionality you are looking for?
There are two methods for integration into other applications: keystroke macros or the launch of a URL
UCCX Premium does support integration.
fadhumohammed Thu, 09/03/2009 - 04:25
hey deljeet,
Iam going to use microsoft crm..and what I eventually want to do is to have the caller(customer) information to be pulled out of crm and displayed on the agent desktop when he receives a call from a existing customer..if its a new customer then a new crm page to be opened..
Is there anyway u can help me on this??
daljeetsingh1_2 Thu, 09/03/2009 - 09:25
It was long back Cisco Introduced Microsoft CRM connector for integration with UCCX. I believe the connector name is "Cisco Unified CRM Connector 3.0 or 4.0".
Check this URL for further details
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/cisco_unified_crm_connector/release/notes/RlsNtsCRM_Connector_for_MicrosoftCRM_Oracle_PeopleSoft_Salesforce.com_1_1_1.pdf
As far as your question goes, you would be having ODBC connection to the CRM database and you need to capture CLI in some variable and then query the database based on that variable and get all the relavant information about caller and then using Enterprise parameters you can pop that information on the CAD.
I am not able to locate the document in my repository which talks about configuration of Popping up data on CAD.
Daljeet
ra_jeshkalra_2 Wed, 11/04/2009 - 18:26
Hi Daljeet,
>> Can you please send a link to the document which talks about "Configuration of Popping up data on CAD".
>>Also if it is possible attach the CRS script doing the pop up.
Thanks in advance
The CRS script simply loads data into "Enterprise Variables" - the payload that is attached to the call as it progresses through the system.
It is CAD that does the screen-pop through a mechanism called "Workflow". The Desktop Administrator enables you to define what actions to take (key stroke macros, launch, HTTP trigger) on given telephony events (ringing, answered, dropped) and what aforementioned Enterprise Variables should be passed.
This is in the CAD documentation.
Geoff
daljeetsingh1_2 Thu, 11/05/2009 - 00:21
Hi Rajesh,
Please see the attached document & test script. We have done popping up CAD at customer sites, however i can't share the scripts with you as its matter of confidentiality with the customer and i have some trouble with CRS Script editor its dies when i login anonymosly, else i would have take that part out from live script and would share that with you.
Daljeet
PS: Please rate the helpful posts.
