LMS 3.1 backup error 292
Sep 3rd, 2009
Can anyone suggest a cure for the following. Last week the inventry job went wrong and filled the entire disk on the server with a 110gb log file.
I cleared that off and since then have not been able to get a backup from the machine. The error message is below.
Backup to 'D:/LMS_Backup' started at: [Thu Sep 3 11:25:00 2009]
[Thu Sep 3 11:25:00 2009] ERROR(292): No database files are available for the installed applications; nothing to back up.
[Thu Sep 3 11:25:00 2009] Backup failed: 2009/09/03 11:25:00
email=[email protected]
host=budmon02
But the main application is running correctly and other jobs are completing without errors.
Thanks in advance
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 09/03/2009 - 09:58
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like the NMSROOT/backup/manifest directory was destroyed. This is very bad. Unless you have a good file system backup of this directory, you may need to reinstall LMS from scratch.
bgl-group Mon, 09/07/2009 - 07:14
Looks like the folder you are mentioning is missing.
I don't have a file system backup for this machine just the ciscoworks backup files.
Am I now looking at a reinstall... or is it possible to do a repair on the directory and then restore an older backup?
Joe Clarke Mon, 09/07/2009 - 10:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The manifest directory can only be recovered from a file system backup, identical LMS server, or from a new install of LMS. If you don't have a file system backup, you can copy the manifest directory from another identical LMS server (i.e. same version of LMS, same applications installed, and same NMSROOT path). If you don't have either of those, then you need to reinstall.
In the future, everything under NMSROOT/backup should NEVER be touched. Do not attempt to write to this directory. It is a critical LMS system directory with no user-serviceable parts.
bgl-group Tue, 09/08/2009 - 02:24
OK looks like a reinstall is going to be required.
Can you see any issues if I reinstall over the original install directory - or do I need to start from scratch?
Joe Clarke Tue, 09/08/2009 - 08:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Hopefully you have one known good data backup from LMS. In that case, uninstall, then reinstall from scratch. Once you have LMS back, and patched to the previous level, then restore that backup, and you should be up and running once again.
bgl-group Wed, 09/09/2009 - 04:21
I have hopefully got some good backups so will look at starting the reinstall in the morning (the last time it took almost 5 hours to install....)
Thanks for your help
Joe Clarke Wed, 09/09/2009 - 09:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is about right. I suspect it will take a good work day to get LMS back up. After that, make sure you take a file system backup just in case.
