mmacdonald70 Sun, 09/06/2009 - 12:56
I have never come across anything like that. I have found perl to be invaluable for this type of situation
Marvin Rhoads Sun, 09/06/2009 - 20:43
Scripting of some sort is probably the best, if not only, practical answer. More important, in my opinion, is the process supporting it. Figure out what you want standards wise - single image to the extent hw supports it, common global and security factors. It could possible be pushed out via CW; most people would agree that a local script might better suit your needs.
Tony.henry Sun, 09/06/2009 - 20:06
Maybe a mail merge might get you out of trouble if Perl scripting isn't your thing..... I'd be guessing there would be a fair amount of mucking around to get it right.
