Dual trunk from access SW--> Single Core- Simple quesry
Sep 3rd, 2009
  • Gold, 750 points or more
Hi All,
Iam planning to add dual trunk links to Single core device from 3560G sw (both end all port hard coded to 1000/full). Spanningtree will block one of the link (core is the root and hence on the access sw). I have this running on other switches as well, but wanted to get experts openion if this is sufficient or is there any additional 'spanning-tree' cost configuration is recomended on one of the trunks so that it always be blocked/backup only.
TIA
MS
Overall Rating: 4 (2 ratings)
Jon Marshall Thu, 09/03/2009 - 05:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
MS
Personally i would combine the links into a L2 etherchannel trunk and that way you don't have to worry about STP.
Is there any reason why you don't want to use etherchannel ?
Jon
mvsheik123 Thu, 09/03/2009 - 05:28
Thanks Jon. 1Gig BW enough here but I will check on this as well. The Core switch ports are different modules (ex: 4/10 & 5/40), it does not matter what module they are . is that correct?
TIA
MS
Jon Marshall Thu, 09/03/2009 - 05:38
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
MS
"The Core switch ports are different modules (ex: 4/10 & 5/40), it does not matter what module they are . is that correct?"
Correct, the ports can be on different modules as long as they are the same speed/duplex etc..
Jon
