Voiceview on CME/CUE 7.1
Sep 3rd, 2009
  • Bronze, 100 points or more
Hi there,
I'm trying to configure VoiceView on CME/CUE 7.1 but I'm running into a roadblock.
Whenever I press the services button on the phone, I receive the "Host not found" message. I've tried using the IP and DNS name in the URL config, but neither seem to work.
I have a 2851 router with NME-CUE:
Router: 10.2.100.50
CUE: 10.2.100.51
CME config:
url directories http://callmanagerexpress/CCMCIP/xmldirectory.asp
url services http://unityexpress/voiceview/common/login.do
url authentication http://callmanagerexpress/CCMCIP/authenticate.asp
CUE Config:
voicemail# sh voiceview config
Phone service URL: http://<CUE-hostname>/voiceview/common/login.do
Enabled: Yes
Idle Timeout (minutes): 5
My voice subnet is 10.1.100.0/24 and my data vlan is 10.2.100.0/24.
The other thing i notice, is that my phones have an odd services URL that I can't seem to replace:
http://10.1.100.1:80/CMEserverForPhone/serviceurl
How do I get the phone to replace that with what I actually have configured?
Also, I have a PC connected to the voice subnet and I am able to browse to http://unityexpress/voiceview/common/login.do and I receive an XML page titled "VoiceView Express Login" -- so I know the page is available...
Thanks in advance,
Brandon
Overall Rating: 5 (1 ratings)
csshenoy80 Thu, 09/10/2009 - 22:01
For the "Host not found", make sure the IP Phones have been enabled for the phone user interface, and have a type defined in the ephone configuration.
Also, make sure your CME config looks like the below, by making changes in telephony-service, you need to point the authentication to CUE.
url services http://10.2.100.51/voiceview/common/login.do
url authentication http://10.2.100.51/voiceview/authentication/authenticate.do
Now, to overcome the Label displayed for the voiceview, configure the below on the CME:
telephony service
url services http://10.2.100.51/voiceview/common/login.do "VoiceView Express"
Hope this helps!
branfarm1 Fri, 09/11/2009 - 03:47
Thanks for the response.
I opened a TAC case and they determined it was a software bug with the IOS. Unfortunately, it's still an "internal" bug, so I couldn't get the bug ID or any information on a fix.
The workaround is to download the configs manually and edit them to have the correct Services URL.
-Brandon
