find err-disabled ports with snmp
Sep 3rd, 2009
I want to find err-disabled ports in our campus with snmp.
unfortunately I only find the following oid 1.3.6.1.4.1.9.9.548.1.3.1.1.2 which is only supported on non modular boxes like the 3560.
is the on modular chassis an oid available to detect err-disabled ports?
Thanks for your responses.
Thorsten
Joe Clarke Thu, 09/03/2009 - 10:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If the device supports it, you can use portAdditionalOperStatus from the CISCO-STACK-MIB. If the value is 10, then the port is in err-disable state.
