Clean Access License issue
Sep 3rd, 2009
I'm implementing a Cisco clean access solution (Out-of-band VG).I've entred the license in the CAM after getting it from Cisco by entering the PAK number.
the problem is that I don't see the Switch management Tab in the menu, also when I want to add a CAS server there is no way to specify the Out-of-band option, there is only Inband and VG.
the problem is reselved temporarely by entering a 30 days license.
Is it a license problem?
how can I resolve this issue?
thanks/.
Faisal Sehbai Sun, 09/06/2009 - 07:17
  • Gold, 750 points or more
The switch management will show when you add a CAS license for OOB to your CAM. Without a CAS license the switch management tabs don't get displayed.
You should have a separate PAK that came with the CAS. Use that PAK and the eth0 MAC address of your manager (NOT your server) to get the CAS license, upload that to your CAM and it should work fine.
