Unity Connection 7 - how to reply with original msg
lkrol
Does anyone know if one can reply to a vm msg with the original vm msg attached in the reply?
Thank you!
Rob Huffman
Ginger Dillon
Hi -
Have you considered the Forward option, as discussed in the excellent link Rob attached to his post? The Forward option is available from the Unity Connection conversation as well as if you have IMAP enabled and ViewMail installed. There is a "Forward with Voice" option in Outlook.
Ginger
Hi. I haven't, but I'm sure that would work. Its a bit strange that one cant reply along with the original, but it is what it is. Thanks!
