CM 4.1(3) upgrading to CUCM 7.0 - New Hardware
Answered Question
Sep 3rd, 2009
Just a quick question: Could someone point me in the right direction for some documentation on upgrading from CallManager 4.1(3) to CUCM 7.0 on new hardware?
We presently have 2 CM servers, one publisher, one subscriber, and will be moving to 3 servers.
What is the most appropriate configuration for these? 1 Publisher, 1 Subscriber, 1 TFTP?
Also is there documentation for migrating the database to the new platform?
Any assistance would be appreciated!
Correct Answer by Rob Huffman about 7 years 7 months ago
Hey Rob,
That is most correct my friend :) Just make sure the "spares" have been configured and you should be good to go!
Cheers!
Rob
Overall Rating: 4.7 (3 ratings)
Jaime Valencia Thu, 09/03/2009 - 08:29
  • Cisco Employee,
  • Hall of Fame,
    2011
Procedure is the same whether it's new or old HW. Only thing that changes is you'll need to rehost the licenses
Upgrading to Cisco Unified Communications Manager Release 7.0(1) from Cisco Unified Communications Manager 4.x Releases
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/7_0_1/upgrd701.html
java
if this helps, please rate
Rob Huffman Thu, 09/03/2009 - 08:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rob,
Here is some related info, with a couple of the common things that seem to "bite" people who are performing this upgrade. I'm sure some of our other NetPro friends will weigh in here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/7_0_1/upgrd701.html#wp146569
Gathering Information for an Installation
Obtaining Software Feature Licenses
You must obtain a software feature license after the upgrade from Cisco Unified CallManager 4.x releases. A software feature license activates features on your system for the specified license version.
Use this procedure to obtain a software feature license:
Procedure
Step 1 Navigate to the License Registration web tool at http://www.cisco.com/go/license.
Step 2 Enter the Product Authorization Key (PAK) that you received with your Cisco Unified Communications Manager upgrade.
Step 3 Click Submit.
Step 4 Follow the system prompts. You must enter the MAC address of the Ethernet 0 NIC of the first node of the Cisco Unified Communications Manager cluster. You must also enter a valid e-mail address. The system sends the license file to you via e-mail using the e-mail address that you provided.
Step 5 You must upload the software license file to the server with the matching MAC address that you provided in Step 4. See the "Uploading a License File" section.
Step 6 After uploading the license file, you must obtain and upload license files for existing nodes and devices
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/7_0_1/upgrd701.html#wp172620
Data Migration Assistant User Guide Release 7.0(1a)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/7_0_1/dmaug701a.html
Migrating from Cisco CallManager 4.0(x) to 7.0(x)
When you migrate from Cisco CallManager version 4.0(x) to 7.0(x), the licenses that are required for existing phones and existing Cisco CallManager nodes is calculated and an intermediate file (XML file) that contains these license counts will be generated during the Cisco CallManager migration process. These licenses are given free of cost because you are already using these phones for Cisco CallManager version 4.x. If you are provisioning new phones and nodes after migrating to Cisco CallManager 7.0(x), you need to paste the intermediate license file in the License Registration window on CCO.
Use the following procedure to register existing licenses and request for new licenses.
Step 1 In Cisco CallManager Administration, choose System > Licensing > License File Upload.
The License File Upload window displays.
Step 2 Click View File. A pop-up window displays that has the license information for existing phones and nodes. Copy this information. To copy the contents on this windrow, you can use Ctrl-A (Select All) and Ctrl-C (Copy).
Step 3 On the License Registration window of CCO website, in the text box provided, paste the file contents using Ctrl-V.
Step 4 You must enter the MAC address of the Cisco CallManager server that you are requesting the licenses for, and a valid E-mail Id.
Step 5 To obtain the actual license file, click Submit. A license file is generated.
Step 6 You must upload the license file to the server with the matching MAC address that you provided in Step 4. See the "Uploading a License file" section in the Cisco CallManager Administration Guide. This node takes on the functionality of the license manager.
...continued on next page
Rob Huffman Thu, 09/03/2009 - 08:37
  • Hall of Fame,
    Founding Member
...from previous page
Go here;
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet
Licenses Not Requiring a PAK
If you do not have a Product Authorization Key (PAK), please click here for available licenses. (use the please click here link)
Available licenses include Evaluation/Demo Licenses, Cisco ASA 3DES/AES, PIX Firewall 3DES/AES and DES Encryption, Cisco Services for IPS, and Cisco Unified Communications Manager Version Upgrade licenses.
Go to;
Voice Products
Then select;
Cisco Unified Communications Manager Device Upgrade License
Here is an overview of the previous info;
Watch out for the note detailed in Step #2 below;
Step 1 After you complete the Cisco Unified Communications Manager upgrade process, navigate to Cisco Unified CallManager Administration and choose System > Licensing > License File Upload.
Step 2 Choose the license XML file from the Existing Files drop-down list, and click View File. The window refreshes and displays the information for the selected license. Copy all of the information in this file except the HTML tags. To copy the contents on this window, choose the appropriate text and choose Ctrl-C (Copy).
Step 3 Navigate to the License Registration web tool at https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet
Step 4 Enter the MAC address of the Ethernet 0 NIC of the first node of the Cisco Unified Communications Manager cluster.
Step 5 In the text box that is provided, paste the license file contents that you copied in Step 2 by using the appropriate keyboard shortcuts, such as Ctrl-V.
Step 6 Enter a valid e-mail address and click Continue. A license file generates.
Step 7 You must upload the license file to the server with the matching MAC address that you provided in Step 4. See the "Uploading a License File" section.
Step 8 You can obtain licenses for new devices that you are adding to the upgraded system, if your system requires additional device license units.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/6_1_2/upgrd612.html#wp1495
Have a look at this great tip from Jason;
"when you capture the xml file for the DLUS etc after the upgrade so that you can post it on Cisco's web site, it might be wrapped in HTML. ie the first line and the last line are html, and the license utility will reject it. Remove the first and last line to resolve this."
Here are some other excellent references;
System Installation and Upgrade Manual for IP Telephony Enterprise and Midmarket
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC7.0.1/ipt_system_inst_upg/suimt701.pdf
Cisco Unified Communications System Documentation
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/ucstart.htm#Cisco_Unified_Communications_System
Cisco Unified Communications Compatibility Tool
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Hope this helps! And best of luck!
Rob
rcoote5902_2 Fri, 09/04/2009 - 11:37
Rob and Java - thank you both for the helpful information. As we progress I am sure I will have some more questions but this will be a great starting point.
Cheers!
Rob
rcoote5902_2 Tue, 09/08/2009 - 12:35
One additional question regarding the licensing.
How does the change in licensing impact existing phone inventory sitting on a shelf? These were purchased under the 4.1(3) system with a license, so would these have to be manually added somehow if/when they are registered with CUCM?
Rob Huffman Tue, 09/08/2009 - 12:54
  • Hall of Fame,
    Founding Member
Hi Rob,
Make sure your spare phones are in the Database and they will be migrated so you can receive the DLU's for them :)
Cheers!
Rob
rcoote5902_2 Tue, 09/08/2009 - 18:09
Thanks Rob,
So they just need to be configured in the database, not registered with the CM? ie: not plugged in to the network?
I wouldn't have enough desk space for that many phones. :)
Rob
Correct Answer
Rob Huffman Wed, 09/09/2009 - 04:25
  • Hall of Fame,
    Founding Member
Hey Rob,
Cheers!
Rob
rcoote5902_2 Wed, 09/09/2009 - 08:32
Thanks again for your assistance. I just plugged in our spare phones - about 45 of them, ugh, and the DMA tool is running. Crossing fingers....
