Qos config..
Sep 3rd, 2009
Hi all..Once again but with diff case.
I have two locations DC & DR connected with two lease line 45+45 Mb.Also configure EIGRP betw these two location for load balancing.
Q. I have one NAS at DC and other replica of that NAS is at DR.High volume of data is transfring betw these server.
I want to configure QOS like 50% of the bw use for two NAS server and 50% for other traffic.
What steps need to be configure for acheiving this............Thanx...
Overall Rating: 4 (1 ratings)
u1kumar2002 Thu, 09/03/2009 - 20:42
Hi Arjun,
There are only few steps to configure the QOS :
1. configure a access list for your NAS server
2. Call that access-list into Class-map.
3. Configure a policy map which can fulfil your requirement of allocation of 50% Bw to that server at any point of time.
4. Apply that policy map to wan interfaces.
May be you will having metroethernet or ethernet connectivity on your end from Service provider.
Ex:
ip access list standard NAS_Server
permit x.x.x.x 0.0.0.0
Class-map match-all NAS
match access-group NAS_Server
policy-map BW_MG
class NAS
bandwidth percent 50
class class-default
fair-queue
exit
apply this cmd on WAN interface
service-policy output BW_MG
show policy-map int fa0/
Try this It should work
arjunsawant Sat, 09/05/2009 - 05:49
Thanx for ur reply...
I have one doubt...On which wan interface i have apply service-policy? B'cause on my router i have two wan interface which are in eigrp for load balancing.
I want to assign 50%(45+45=90MB) of bandwidth to NAS.
is it possible?
Thanx...
arjunsawant Sat, 09/05/2009 - 10:25
Thanx.......
I'll try.
Is it require to configure on both router DC and DR?
arjunsawant Sun, 09/06/2009 - 05:28
Hi....
I configure on DC,
class-map match-all NAS
match access-group name NAS_OUT
policy-map NAS_BW
class NAS
class class-default
fair-queue
interface FastEthernet0/0
bandwidth 1000
ip address 10.5.1.149 255.255.255.252
duplex auto
speed auto
service-policy output NAS_BW
interface FastEthernet0/1
bandwidth 1000
ip address 10.5.1.161 255.255.255.252
duplex auto
speed auto
interface FastEthernet1/0
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
router eigrp 111
redistribute connected
network 10.0.0.0
no auto-summary
ip access-list extended NAS_OUT
permit tcp host 10.0.0.175 host 10.1.0.75 eq 10001
permit tcp host 10.0.0.176 host 10.1.0.76 eq 10001
permit icmp host 10.0.0.175 host 10.1.0.75 echo
permit icmp host 10.0.0.175 host 10.1.0.75 echo-reply
permit icmp host 10.0.0.176 host 10.1.0.76 echo
permit icmp host 10.0.0.176 host 10.1.0.76 echo-reply
But when i send some icmp traffic, it shows only on one interface.
DC#sh policy-map inter fastEthernet 0/0
FastEthernet0/0
Service-policy output: NAS_BW
Class-map: NAS (match-all)
510 packets, 58140 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name NAS_OUT
Queueing
Output Queue: Conversation 265
Bandwidth 50 (%)
Bandwidth 500 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 9/1026
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
131 packets, 10362 bytes
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
DC#sh policy-map inter fastEthernet 0/1
FastEthernet0/1
0 packets, 0 bytes
Queueing
Bandwidth 50 (%)
(pkts matched/bytes matched) 0/0
120 packets, 9918 bytes
Match: any
Queueing
Is there any wrong in config?
Pls suggest......
DC#
