dial-peer problem from ISDN fax to CUCM via H323
We have a ISDN fax connected to a BRI port on the 2800 router. The BRI port is configured as layer 1 to 3 emulate network, so it can talk with fax.
We have configured ad couple of DP :
one (DP #10) to connect to the CUCM server via H323 session, and the other (DP#200) to bind the BRI voice port.
here is the main DP configuration lines:
dial-peer voice 10 voip
description to CUCM
destination-pattern 0T
voice-class h323 1
session target ipv4:192.168.10.10
dtmf-relay h245-alphanumeric
supplementary-service pass-through
dial-peer voice 200 pots
description Peer ISDN FAX
destination-pattern 9199
port 0/1/1
We have a analogic fax (DN 101) on CUCM and we sucesfully send faxes to the ISDN one, but not viceversa.
Attached I will include the output of the "debug voip dialpeer all"
It seem the FAX call cannot reach any output DP because of TYPE mismatch.
I think the router detect fax signal
although the voice-port is configured with a "bearer-cap Speech" option.
how we can route the outgoing fax towards CUCM H323 connection?
Many thanks
