Multicast receiver not receiving mcast from sender on same vlan
Sep 3rd, 2009
I have a situation where I have multicast sender and receiver on the same physical switch on the same vlan.
The receiver is not able to join the senders mulitcase group. I do have IGMP snooping enabled and was hoping not to have to disable it. (Not that disabling would work either....)
One thing to note is on the upstream router (I'd call this the multicast router) I've configured sparse-mode and also built a GRE tunnel to get multicast to another location. Receivers at the remote location (On a different subnet) are able to receive all the senders mcast feeds! It seems to be isolated to the sender and receivers on the same subnet off the same switch that can't receive/join groups. Below is part of the config on the router. Nothing special off the switch.
Switch: C7000 (inside an HP Blade server chassis)
Router: Cisco 7206
router config:
ip multicast-routing
ip dvmrp interoperability
interface Loopback1
description TUNNEL SOURCE TO XXX FOR MULTICAST
ip address 10.10.254.1 255.255.255.255
ip pim sparse-mode
interface Tunnel0
description MULTICAST TUNNEL TO XXX TUNNEL 0
ip address 10.10.253.1 255.255.255.252
ip pim sparse-mode
tunnel source Loopback1
tunnel destination 10.10.254.2
interface GigabitEthernet0/2
no ip address
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/2.10
description *** LAN, MGMT VLAN ***
encapsulation dot1Q 10
ip address 10.10.0.1 255.255.255.0
ip pim sparse-mode
interface GigabitEthernet0/2.12
description *** LAN, SERVERS VLAN ***
encapsulation dot1Q 12
ip address 10.10.2.1 255.255.255.0
ip pim sparse-mode
ip pim rp-address 10.10.254.2
ip mroute 192.168.17.0 255.255.255.0 Tunnel0
ip mroute 10.10.254.2 255.255.255.255 Tunnel0
ip mroute 10.10.2.0 255.255.255.0 10.10.0.1
The receiver is 10.10.2.10 & 24 trying to recieve from any of groups 224.1.1.1, .2, or .3
show IP mroute:
(*, 224.1.1.1), 01:19:40/stopped, RP 10.10.254.2, flags: SJCF
Incoming interface: Tunnel0, RPF nbr 10.10.253.2, Mroute
Outgoing interface list:
GigabitEthernet0/2.12, Forward/Sparse, 01:08:26/00:02:20
(10.10.2.20, 224.1.1.1), 01:19:40/00:03:28, flags: FT
Incoming interface: GigabitEthernet0/2.12, RPF nbr 0.0.0.0, Registering (data-header)
Tunnel0, Forward/Sparse, 01:19:35/00:02:36
(*, 224.1.1.3), 01:19:36/stopped, RP 10.10.254.2, flags: SJCF
GigabitEthernet0/2.12, Forward/Sparse, 01:08:27/00:02:20
(10.10.2.20, 224.1.1.3), 01:15:31/00:02:59, flags: PFT
Outgoing interface list: Null
(*, 224.1.1.2), 01:19:41/stopped, RP 10.10.254.2, flags: SJCF
GigabitEthernet0/2.12, Forward/Sparse, 01:08:26/00:02:19
(10.10.2.24, 224.1.1.2), 01:16:17/00:02:59, flags: PFT
(*, 224.0.1.40), 01:19:43/00:02:19, RP 10.10.254.2, flags: SJCL
Loopback1, Forward/Sparse, 01:19:43/00:02:19
Overall Rating: 3 (2 ratings)
Peter Paluch Thu, 09/03/2009 - 14:37
  • Cisco Employee,
If the multicast sender and receiver are on the same physical switch and on the same VLAN then the router should indeed not be necessary here.
Can you check and post the output of the "show ip igmp snooping group" of that switch? Also, on which ports are the sender and receiver located? By the way, what is the IGMP version used by the receiver? Can you try to force it to be IGMPv2? Some switches have problems with IGMPv3. Also, do you have any storm control or switchport block configured? Is it perhaps possible to post the configuration of the switch?
Also please be more specific about the IP address of the sender and the individual multicast groups.
Thanks!
Best regards,
Peter
mortonjes Thu, 09/03/2009 - 15:43
Yes, the receiver and sender are on the same physical switch and on the same vlan.
Show ip igmp snooping group:
C7000-1-SW#sh ip igmp snooping groups
Vlan Group Type Version Port List
12 224.1.1.1 igmp v2 Gi2/0/5, Gi2/0/11,
Gi2/0/15, Gi2/0/26
12 224.1.1.2 igmp v2 Gi1/0/10, Gi2/0/11,
Gi2/0/26
12 224.1.1.3 igmp v2 Gi2/0/11, Gi2/0/15,
Gi2/0/26
12 230.230.230.230 igmp v2 Gi2/0/11, Gi2/0/26
C7000-1-SW#
Sender: port g2/0/11
Receiver: port g2/0/15
I dont believe I have any storm control configured unless there is some sort of storm control enabled by default. No switchport blocked. Below is the config of the switch minus interfaces that aren't configured:
version 12.2
no service pad
service password-encryption
hostname C7000-1-SW
boot-start-marker
boot-end-marker
!witch 1 provision ws-cbs3120g-s
switch 2 provision ws-cbs3120g-s
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
ip multicast-routing distributed
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 10
name MGMT
vlan 12
name SERVERS
interface GigabitEthernet1/0/11
switchport access vlan 12
spanning-tree portfast
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet2/0/26
description TRUNK TO 7206 G0/2
switchport mode trunk
interface Vlan10
ip address 10.10.0.2 255.255.255.0
ip pim passive
ip route 0.0.0.0 0.0.0.0 10.10.0.1
Thanks for the help!
mortonjes Thu, 09/03/2009 - 15:53
I noticed that I have the command
"ip multicast-routing distributed" on what I want to use as my switch. (Meaning this device is layer 3 capable but I am using it for layer 2 except for one unrelated connection.)
Could the fact that I have ip multicast-routing distributed configured on this layer 3 switch, be preventing layer 2 multicast functionality?
C7000-1-SW#sh ip igmp snooping querier
Vlan IP Address IGMP Version Port
10 10.10.0.2 v2 Router
12 10.10.2.1 v2 Gi2/0/26
C7000-1-SW#
Vlan 12 is where all multicast is originating from.
Giuseppe Larosa Thu, 09/03/2009 - 20:18
  • Hall of Fame,
    Founding Member
Hello Jesse,
an IGMP querier is detected in Vlan12.
However, I would try the following:
create SVI interface Vlan12 with appropriate ip address and enables ip pim sparse mode on it.
your note about ip multicast-routing looks like meaningful.
Hope to help
Giuseppe
Peter Paluch Fri, 09/04/2009 - 05:59
  • Cisco Employee,
Hello Jesse,
As Giuseppe has indicated, removing the "ip multicast-routing" might be worth trying although I would be surprised it if helped.
Giuseppe, can you please confirm my observation that according to the "show ip igmp snooping group", the switch recognizes both the source and the receiver ports and should be forwarding the multicast stream?
Jesse, you have written that the configuration shown above contains the ports that are not left at their default configuration. However, the ports shown in the configuration are Gi1/0/x while the other show commands say about Gi2/0/x - is that just a typo? If not then please let us also see the configuration of the Gi2/0/x interfaces.
Best regards,
Peter
mortonjes Fri, 09/04/2009 - 13:47
Hi Peter.
To address your question about interfaces indicated in my posts...if I'm understanding you correctly, you're comparing my first post to my second post. If this is correct, my first post reflects my router interfaces while the other configureation represents the switch configuration. I am a bit stumpted (easy to do) as well, because since the sender and receiver are on the same physical switch and vlan, not layer 3 device should be needed to forward the mcast stream.
Any additional thoughts are greatly appreciated.
Jesse
Peter Paluch Sat, 09/05/2009 - 00:14
  • Cisco Employee,
Hi Jesse,
I am referring to this post:
Gi2/0/15, Gi2/0/26
Gi2/0/26
Gi2/0/26
C7000-1-SW#
A few lines under it, there a configuration snippet of the C7000-1-SW, however, the ports there are Gigabit1/0/x, not Gigabit2/0/x.
Best regards,
Peter
mortonjes Fri, 09/04/2009 - 13:49
Hello Giuseppe. Thank you for looking at my post. I am not sure how to configure an SVI interface. I will have to read up on it and try it. Am I correct in assuming that the SVI interface should be created on the switch?
Much thanks,
Jesse
Giuseppe Larosa Fri, 09/04/2009 - 22:38
  • Hall of Fame,
    Founding Member
Hello Jesse,
yes it should be created on the switch with
conf t
int vlan 12
ip address 10.10.2.x 255.255.255.0
ip pim sparse-mode
no shut
! choice a free ip address in vlan 12 for the SVI
I would also
int vlan10
ip pim sparse-mode
add also the correct
ip pim rp
command
I see on the router a strange mroute regarding ip subnet of vlan12 with a local next-hop that of vlan10.
However, an IGMP querier is detected and sh ip igmp group shows ports for sender, router interface and receiver in vlan12.
Hope to help
Giuseppe
mortonjes Sat, 09/05/2009 - 16:27
Yes. I see the erroneous staic mroute you mentioned. Hmmm, that shouldn't be there. Thank you for point that out. (I'm not sure if removing that static mroute will fix my issue, but it definitely not be there.)
Thank you
Mohamed Sobair Fri, 09/04/2009 - 14:54
  • Gold, 750 points or more
Hi Jesse,
Does the Multicast sender and reciever both on vlan 12 or in differnet Vlans? I notice you have ports on vlan 12 while clan 10 is managment right?
If its on the same Vlan, then you should with the current config.
If its on differnt SVI, then enable pim on both layer-3 SVIs with (Ip multicast routing distributed) and you should be good to go.
On the other hand, the command (IP IGMP Snooping) is helpful whenever there is IGMP query from a router or a layer-3 Interface, it allows the switch to build a multicast table tp the appropriate multicast recievers.
Mohamed
mortonjes Sat, 09/05/2009 - 16:32
Hi Mohamed. Yes, both sender and receiver in this case are on the same vlan. (vlan 12) You are also correct. I am using Vlan 10 for management. (I dont really need multicast to or from vlan 10)
Thing is, even though this switch is layer 3 capable, I would really like to keep its function as layer 2 device only. So, if possible, I'd like to keep layer 3 functions off. I will build SVI interfaces and enable PIM but do you think I can get around that? (Just use this device as layer 2 only with regards to multicast?)
Thank you all very much for your help so far.
Jesse
Mohamed Sobair Sun, 09/06/2009 - 05:08
Hi Jesse,
You dont actually need layer-3 here.
However, if the Multicast sender and reciever on the same vlan , then you dont need extra config and the multicast packet should be forwarded to the all ports of vlan 12 except the port a multicast packet recieved on.
The config suggested by Gui and Peter I believe because of the (sh igmp snooping group) output which shows the reciever and sender detected on different vlans and different ports. If its not in different vlan then you dont need to assign an SVI interface on vlan 12.
Mohamed
Peter Paluch Sun, 09/06/2009 - 06:14
  • Cisco Employee,
Hello Mohamed,
Can you please re-post the output snippet where you see that the sender and recipient are on different VLANs? I can't find it - I am probably missing something.
Best regards,
Peter
Mohamed Sobair Sun, 09/06/2009 - 16:28
Hello Peter,
I was refering to your earlier post bellow:
Gi2/0/15, Gi2/0/26
Gi2/0/26
Gi2/0/26
C7000-1-SW#
I was also refering to the IGMP Querier and reciever not the multicast sender and reciever.
Based on the describtion of the original poster, do you think he needs layer-3 here? Also do you think troublshooting IGMP would produce useful information if the sender and reciever of the multicast stream are on the same vlan?
Mohamed
Peter Paluch Sun, 09/06/2009 - 16:48
  • Cisco Employee,
Hello Mohamed,
Personally, I do not think that the original poster need a Layer3 multicast routing here. As he indicated himself, the sender and receiver are on the same VLAN so this all should run without any routing support.
Troubleshooting the IGMP in my opinion is important here as the switch is performing IGMP snooping. Until the switch correctly identifies the subscriber ports, the multicast traffic will not be delivered to those ports. What confuses me strongly, however, is that according to that "show ip igmp snooping groups" output, the switch knows both about the sender and receiver port, and yet the multicast traffic is not being delivered. Can you see it, too? I am trying to think of anything that would prevent a switch from replicating multicast traffic although it knows about the particular receivers but right now I don't see any reason why that should not work - and yet it doesn't.
Any idea?
Best regards,
Peter
mortonjes Mon, 09/07/2009 - 15:18
First off, thank you all very much for looking into my issue. I agree, with the sender and receiver both on the same physical switch and vlan (vlan 12) I wouldn't think any layer 3 deivce would be needed.
Tomorrow, (9/7/09)I am going to try some of the things suggested in this thread. (Removing erroneous staic mroute, removing mulicast routing on the layer 3 switch and if all else fails, just for a test, removing IGMP snooping)
I will post my findings tomorrow.
You're assistance is greatly appreciated!
Jesse
mortonjes Tue, 09/08/2009 - 17:45
I wasn't able to work on this today. I would liked to. The person who handles our Linux servers was out.
(Mcast sender/receivers are on the Linux platform)
I will post tomorrow. Thanks
Jesse
Giuseppe Larosa Tue, 09/08/2009 - 08:41
  • Hall of Fame,
    Founding Member
Hello Mohamed,
Absolutely yes when sources and receivers are in the same vlan IGMP snooping can be the source of problems.
Here we have a device that is in the middle:
it could be configured as a L2 switch but it has ip multicast routing enabled.
It has ip pim passive on vlan10 no pim configuration in vlan12 (no SVI vlan12 actually exists)
Or it becomes a full L3 multicast router creating pim neighborships on vlan10 and vlan12 or it has to be configured as L2 only for ipv4 multicast.
Being in the middle is not good.
multicast stream Traffic is forwarded to port gi2/0/26 because a multicast router is detected over it.
User port gi2/0/15 is listed among the ports associated to group 224.1.1.3 but it doesn't receive traffic.
Example:
When we tested RGMP for the first time on a C6500 some years ago, it didn't work and then we found a workaround by creating an SVI on the vlan. (in later releases this is not needed).
Hope to help
Giuseppe
ragulan_dms Wed, 09/09/2009 - 04:23
Hi all,
Correct me if i correctly understand you. Say sender and receiver are belongs to same vlan. No L3 multicast routing (PIM) is enabled on the vlan interface. On Cisco switch IGMP is enabled by default. Since theoretically it should work.
I think i have seen something similar. But it worked. But multicast stream seems to be flooded to all the port on the switch irrespective of receiver port (even igmp globally enabled). Receiver was able receive the stream, But with " sho ip igmp snooping group" did not show anything.
So I am eagerly waiting for the Jesse's testing. Please update your testing. (You may try to connect you PC to one of the port and just listen using ethereal)
Ragu.
mortonjes Wed, 09/09/2009 - 11:27
I was able to do some testing with my Linux group. Here is what I did. (in order)
1.) Verified that multicast was in fact working over my tunnel. (It was)
2.) Removed "sparse-mode" from interface GigabitEthernet0/2.10. (It wasn't needed.)
2a.) Cleared ip mroute * on the router (My lack of knowing if clearing mroute was necessary.)
2b.) Checked to see if mcast was still working over tunnel. (It was.)
2c.) Checked to see if sender and receiver on vlan 12 was working. (Still wasn't working.)
3.) Removed this route from the router: ip mroute 10.10.2.0 255.255.255.0 10.10.0.1
3a.) Cleared ip mroute * on the router (My lack of knowing if clearing mroute was necessary.)
3b.) Checked to see if mcast was still working over my tunnel. (It was.)
3c.) Checked to see if mcast was working on vlan 12. (Still wasn't working.)
4.) I removed this command of the layer 3 switch: ip multicast-routing distributed
4a.) Cleared ip mroute * on the router (My lack of knowing if clearing mroute was necessary.)
4b.) Checked to see if mcast was still working over my tunnel. (It was.)
4c.) Checked to see if mcast was working on vlan 12. (Still wasn't working.)
5.) I asked my Linux group to verify with me the ports that the sender and receiver were on.
6.) To my surprise (my fault for not looking at this more in depth sooner) The sender was on g2/0/11 and the receiver was on g1/0/15.
7.) This switch is in an HP Blade server chassis so I started thinking maybe the sender and receiver are NOT on the same physical switch. (Even though when you look at the switch module in the HP chassis it looks like one module. And when I'm logged into the switch, I can see all ports g1/0/x - g2/0/x within the same session without having to jump to another set of ports/session to another module)
8.) so I had the Linux group pick a sender and receiver on the same port structure. (2
servers off the g2/0/X)
9.) Still, mcast didn't work!
10.) Lastly, I disabled snmp snooping. As expected, that worked. Both sender and receiver were able to see each other AND sender on g2/0/X was able to reach with receiver on G1/0/x
The switch is in a HP Blade enclosure and show ver off the switch is in my next post (please see next post)
Questions:
1.) Why does it take disabling of IGMP snooping to make this work? (Even with sender/receiver on same set of ports? G2/0/X)
2.) We currently don't have a lot of multicast traffic but will be adding more to the network in the future. At what point does having IGMP Snooping disabled, affect network performance?
Any advice on how to get this to work without disabling IGMP Snooping? (I'm sort of hung up on this idea that disabling IGMP Snooping is not the most optimal way to go.)
Thank you so much for all the help.
Jesse
mortonjes Wed, 09/09/2009 - 11:28
Show ver off the switch:
SWITCH SHOW VER:
cisco WS-CBS3120G-S (PowerPC405) processor (revision C0) with 245760K/16376K bytes of memory.
Processor board ID XXX
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:23:5D:C6:3F:00
Motherboard assembly number : 73-10920-08
Motherboard serial number : XXX
Model revision number : C0
Motherboard revision number : A0
Model number : WS-CBS3120G-S
System serial number : XXX
Top Assembly Part Number : 800-28497-01
Top Assembly Revision Number : F0
Version ID : V01
CLEI Code Number : COUIAN0CAA
Hardware Board Revision Number : 0x00
Switch Ports Model SW Version SW Image
* 1 26 WS-CBS3120G-S 12.2(46)SE CBS31X0-UNIVERSALK9-M
2 26 WS-CBS3120G-S 12.2(46)SE CBS31X0-UNIVERSALK9-M
Switch 02
Switch Uptime : 16 weeks, 22 hours, 8 minutes
Base ethernet MAC Address : 00:23:AB:FF:A4:00
Top assembly part number : 800-28497-01
Top assembly revision number : F0
Version ID : V01
License Level : XXX
License Type : XXX
Next reboot licensing Level : XXX
Configuration register is 0xF
C7000-1-SW#
Giuseppe Larosa Fri, 09/11/2009 - 12:52
  • Hall of Fame,
    Founding Member
Hello Jesse,
I think your device is not behaving correctly about IGMP snooping.
I haven't a direct experience with this switch on a blade.
I would suggest you to open a TAC Service Request.
Hope to help
Giuseppe
Mohamed Sobair Sat, 09/12/2009 - 15:09
Hi Jesse,
Very strange symptom indeed.
here is the answers for your questions:
This shouldnt affect your multicast, IGMP snooping allows the switch to build multicast table to include which reciever's ports should recieve particular multicast stream from the IGMP querior (sender), So whether you disable it or not, with the normal behaviour it should work fine.
As mentioned, IGMP Snooping provides Optimization method on the network, it allows the switch to identify which ports should recieve particular multicast streams instead of flooding the multicast to all ports on the switch by listining to IGMP Join messages and record the related host ports and identify the correct IGMP querior port.
Mohamed
