The Easy VPN Remote feature
Sep 3rd, 2009
How do you configure The Easy VPN Remote feature for the ASA? "The feature pushes security policies defined at the central site to the remote device, so that it has up-to-date policies in place before a connection is established'. It would be helpful to set up policies like the client must have up-to-date MS patches and the latest antivirus strings inorder to establish a connection with HQ. How do you configure the policies and maintain them? Has anyone ran into issues after implementing the above?
