Visio Stencils for UCCX Editor
I have Visio stencils for the generic CCM objects. However I am looking for Visio Stencils that represent the Icons in the Script Editor. Has anyone found something like that?
gary.fearn
A little late but you can get a HTML version of a Script Editor script using this tool.. http://icmstransform.co.uk
10 years is "a little late?" ;)
Also, the OP asked about UCCX, which uses .aef files. The site you referenced requires .icms files, which is for UCCE.
For what it's worth, I'm not even sure what the OP was asking for. Like a Visio icon for each step in the editor?
EDIT: I just realized this is your site.  I also see that you run https://ciscocontactcentersecrets.wordpress.com/, which looks pretty informative.  I'll definitely have a look around!
Ratheesh Kumar
Hi there
For UC components, normally I use the modern flat CVD icons and for UCCX Scripting if you want to can use the aef icon picture itself for presentation purpose. I dont think we have something for the scripting
https://www.cisco.com/c/en/us/solutions/enterprise/design-zone-smart-business-architecture/cvd.html
AEF Icon
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
