SPC running on linux
Patrick Born Tue, 09/08/2009 - 15:36
Hi thechet69,
It works for me on Ubuntu 9.04 Jaunty Jackalope.
Here's what I did:
[email protected]-blade:~/Downloads/spa525g_SPC$ chmod 544 spa525g-sip-7-2-3-spc-linux-i386.bin
[email protected]-blade:~/Downloads/spa525g_SPC$ ./spa525g-sip-7-2-3-spc-linux-i386.bin
  Sipura Profile Compiler -- SPA525G-SIP Revision 7.2.3
  Copyright (c) 2006 Cisco-Linksys.  All rights reserved.
  usage 1: spc [opt_args] source_text_file target_binary_file
  usage 2: spc --sample-profile output_filename
  usage 3: spc --sample-xml [--va] output_filename
  usage 4: spc --sample-xml-compact [--va] output_filename
  usage 5: spc --xml-schema output_filename
    --cmd-file file_name            Reads additional arguments from file
    --target hex_string             12 hex-digits MAC Address of target
    --scramble ascii_string         Plain ASCII obfuscation string
    --rc4                           Alleged RC4 256 Stream Cipher
    --aes                           AES Block Cipher (CBC mode)
    --ascii-key  ascii_string       Plain ASCII encryption password
    --hex-key  hex_string           Binary encryption key
    --quiet                         Do not print status messages
    --log file_name                 Log status messages to file
  spc profile syntax:  parName [ '!' | '?' ] [ "parValue" ] ';'
[email protected]-blade:~/Downloads/spa525g_SPC$ ./spa525g-sip-7-2-3-spc-linux-i386.bin --sample-xml spa525G_template.xml
  spc: generated SPA525G-SIP sample configuration spa525G_template.xml
[email protected]-blade:~/Downloads/spa525g_SPC$ ./spa525g-sip-7-2-3-spc-linux-i386.bin --sample-profile spa525G_profile.txt
  spc: generated SPA525G-SIP sample configuration spa525G_profile.txt
I've attached the generated files for  you.
thechet69 Tue, 09/08/2009 - 18:34
Thanks.  The chmod was what I needed.  Can I download a config from a phone using SPC?  I see the --target argument though have been unsuccessful on download the config from a phone using the mac.
jlhbjnhh67 Tue, 03/13/2012 - 05:16
Where can I download this utility /- /spa525g-sip-7-2-3-spc-linux-i386.bin
Are there different file for each model?
Thank you.
Patrick Born Tue, 03/13/2012 - 09:01
Hi Jonathan,
There is a different SPC utility file for each version of firmware and for each of SPA3xx/50x, SPA51x, and SPA525.
SPC are available from.
I suggest you use 7.4.9 instead of the older 7.2.3 firmware that you're looking for.
Check out reference document the locate firmware, SPC, and other phone related application notes.
jlhbjnhh67 Tue, 03/13/2012 - 09:13
Great. Thank you.  Is this the tool use to encrypt the config files as well?
Patrick Born Tue, 03/13/2012 - 09:26
Yes, run the command without any options and it will display help.
Read more about the SPC tool in the Provisioning Guide.
joemeyer89 Thu, 03/06/2014 - 10:25
Do have instructions for MAC OS X 10.7.5. I know how to do it with windows. Our company went all MAC now so I am on a learning curve. Any suggestions would be greatly appreciated.
