2 ASA 5505's All Sorts of VPN Problems
Sep 3rd, 2009
I have ASA 5505's up until yesterday they had a working VPN for months. Yesterday we had to change the public IP's for both 5505's. The first ASA #1 has about a dozen VPN's configured on it and is having no other issues except for this particular VPN. The other ASA #2 also had it's IP changed yesterday it has had problems with 2 of 5 different VPN's. One of the two VPN's is connecting to #1. When you try to initiate the connection from #1 I get tons of errors:
5 Sep 03 2009 21:36:00 713257 Phase 1 failure: Mismatched attribute types for class Group Description: Rcv'd: Group 2 Cfg'd: Group 1
Dozen's of these before the VPN finally connects. I can't for the life of me find any different settings between the two of them. If they are set to use aggressive mode the VPN will still get all the errors but will not come up. I've deleted it on both sides and re-created it, still doesn't work right.
networker99 Fri, 09/04/2009 - 06:02
I presume that you have multiple ISAKMP policies configured?. Are the ISAKMP policies listed in the same order on both sides? as the initiating side will send its proposal and compare against the peers first, and then the second if no match is found..
nmooremvsc Fri, 09/04/2009 - 06:04
Yes, the first policies on both match, the final policies on both match as well.
networker99 Fri, 09/04/2009 - 06:07
There is some inconsistancy with the ISAKMP policy.. can you post the config as well as the output from "debug crypto isakmp 8"
networker99 Fri, 09/04/2009 - 07:03
oh,.,. just realized I have had this before. In the end I had to completely delete and rebuild the ISAKMP and Crypto Map statement. Used the same settings
nmooremvsc Fri, 09/04/2009 - 07:12
Delete the entire crypto map statement or just that numbered section?
networker99 Fri, 09/04/2009 - 07:21
You could try that first. I believe it was in the name so I would create a brand new one (just copy and paste the old changing the name) and apply it to the interface
