Joe Clarke Thu, 09/03/2009 - 21:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can't. Campus Manager 5.3 doesn't exist. the latest version is Campus Manager 5.2 which is part of LMS 3.2. The LMS 3.2 upgrade can be downloaded from http://www.cisco.com/go/lms/ . If you install the eval version on top of a licensed LMS 3.1, you will have a fully licensed LMS 3.2.
akash03lingam Thu, 09/03/2009 - 21:28
sorry, I have mentioned wrongly. Its campus manager 5.1.3. I have downloaded and want to know the steps for the upgradation
Joe Clarke Thu, 09/03/2009 - 21:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Just uncompress it, and run the executable. Make sure you do this as a local Administrator, and disable anti-virus before starting.
akash03lingam Thu, 09/03/2009 - 21:39
If i run the upgradation file, will the LMS stops working until the upgradation finished.
2)Do i need to reboot the server after upgradation.
Joe Clarke Thu, 09/03/2009 - 21:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The installer will stop Daemon Manager, so LMS will be done until the upgrade is finished. No, a reboot should not be necessary. However, if the installer detects that one is required, it will prompt you, and you should do so before trying to use LMS.
