ACS Tacacs administration report Log Analyzer
Sep 4th, 2009
  • Silver, 250 points or more
The logs in ACS are in .csv format. My system is generation huge logs due to more than 1000 devices configured in ACS. Is there any tools available to analyze the Tacacs administration logs ?
Hitesh Vinzoda
Jatin Katyal Fri, 09/04/2009 - 04:17
  • Cisco Employee,
Hi Hitesh,
The only option you have is to download the .CSV files and import it into spreadsheets by using most popular spreadsheet application software. You can also use a third-party reporting tool to manage report data. For example, aaa-reports! by Extraxi supports ACS.
To download a CSV report:
# click Reports and Activity.
# Click the CSV report filename that you want to download.
# In the right pane of the browser, click Download.
# You can easily analyse the logs in Microsoft excel
How to filter and analyze logs ( with Regular Expression Syntax Definitions):
http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/LgsRpts.html#wp632961
For downloading third party application
http://www.extraxi.com/
For more info, you can download the user guide:
http://www.extraxi.com/PDFs/aaa-reports%20sales%20proposal%20-%20customer.pdf
JK
