RME collection Status problem
Sep 4th, 2009
In RME collection status under config archive in partially successfull tab i am getting this error message " Command failed VLAN Config fetch is not supported using TFTP. Could not detect SSH protocols running on the device VLAN Config fetch is not supported using RCP. " please explain this eror message.
Joe Clarke Fri, 09/04/2009 - 08:23
The VLAN config can only be fetched using SSH or telnet. RME will connect tot he device, then issue a "copy flash:vlan.dat tftp:". This error says that RME could not detect that SSH was running on the device, and telnet did not appear to be in the protocol order.
Joe Clarke Mon, 09/07/2009 - 10:19
Make sure you can establish an enabled SSH or telnet session from the CiscoWorks server using the same credentials that are configured in DCR.
akash03lingam Wed, 09/09/2009 - 06:10
Could you please tell me how can i delete the old status under partially sucessful tab in RME
Joe Clarke Wed, 09/09/2009 - 10:10
Assuming you've worked out the connection issues, go to RME > Config Mgmt > Archive Mgmt > Sync Archive, and check the Fetch Startup box. If the Sync Archive job runs successfully (and all configs are fetched), then the device will move to a Successful state.
