09-04-2009 02:45 AM - edited 03-15-2019 07:38 PM
Customer wants to check that data can be backed up on a spare server in case they need to replace production Publisher in the future. The production UCM cluster is running 6.1.3 (Publisher and single Subsriber). Problem is that I wasn't able to restore data from a backup. These are the steps performed:
Installed 6.1.2 from DVD
Installed 6.1.3 patch (this patch provided 1 demo node license).
Start Services on UCM.
Run Restore from a backup taken from the production ucm few days ago.
When I run restore after a few minutes I get an error message 'No features found in backup'.
I can verify through UCM administation pages that the backup was unsuccessful.
Has anybody come across this before or know why I am geeting this error message?
Solved! Go to Solution.
09-04-2009 09:12 AM
Hi ,
I think what Michael is referring to is this line from your first post;
"I can verify through UCM administation pages that the backup was unsuccessful".
Where I think you meant to put in "Restore" rather than "Backup" :)
So it seems that the problem here is likely with the Backup rather than the Restore. Have a look at the "Features" that you asked the DRS to Backup and maybe try running a new Manual Backup with the following (as needed)
Supported Features and Components
Disaster Recovery System can back up and restore the **features and components that are shown in table Table 3. For each feature that you choose, the system backs up all of its components automatically.
Table 3 Supported Features and Components
Feature Components
CCM (CCM/CAR/CDR Repository Manager)
Cisco Unified Communications Manager database (CCMDB) includes Cisco Unified Communications Manager/CDR Analysis and Reporting/Call Detail Records)
Platform
(MOH) Music On Hold Audio Files
BAT Bulk Provisioing Service(BPS)
CCMPREFS Preference files
TFTP (TFTP Phone device files)
SYSLOGAGT SNMP (SNMP syslog component)
CDPAGT SNMP (SNMP cdp subagent)
TCT(trace collection tool)
CLM cluster Manager
You may be seeing this
Error
CiscoDRFNoRegisteredFeature
No feature got selected for backup.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_1_2/DRS_CUCM/drsag612.html#wp255591
Hope this helps!
Rob
09-04-2009 04:26 AM
You said "I can verify through UCM administation pages that the backup was unsuccessful".
If backup was unsuccessful, how could you expect restore to work?
Michael
09-04-2009 06:53 AM
Thanks for your response. However I'm not sure what you mean...
I would expect that a successful restore will configure the spare server with the same configuration as the production Publisher.
As I explained the message I got a few minutes after I attempted a restore was 'could not find features'.
I checked the admin pages to see if any of the configuration on the spare server matched the production Publisher.
Is this something you can help me with?
09-04-2009 09:12 AM
Hi ,
Feature Components
Platform
CLM cluster Manager
Error
Hope this helps!
Rob
09-04-2009 10:57 AM
Hi Rob,
I meant "Restore" rather than "Backup". Thanks for spotting that and for your response. I'll check the backup settings next week.
G
09-08-2009 03:27 AM
Hi Rob,
I checked to make sure that features had been selected on the backup configuration. The 'CCM Features selected' checkbox was selected so the problem was not with the backup.
I had a look through the link you sent me and realised that the problem was down to the fact that I had not manually entered the subscriber node in the server list...
Once I entered the subscriber details the restore was successfull........ (yes I know I should have read the instructions!)
Thanks for your help
