Short LACP Timeout on Catalyst 3560G
Sep 4th, 2009
I want to enable short LACP timeouts on a Cisco Catalyst 3560G running IOS 12.2(50)SE1.
Does Cisco support short LACP timeouts on this switch? I cannot find the right command to do so.
My current config is:
interface GigabitEthernet0/5
lacp port-priority 600
channel-protocol lacp
channel-group 1 mode active
spanning-tree portfast
interface GigabitEthernet0/6
lacp port-priority 700
interface Port-channel1
lacp system-priority 1200
Any help will be appreciated. Thanks.
simontibbitts Fri, 09/04/2009 - 05:53
Hello.
I think the command you are looking for is 'lacp rate fast'
Unfortunately this is only supported on the 6500.
Simon
