Sharing VLAN ports
Answered Question
Sep 4th, 2009
Is it possible to share ports among different VLANs for Catalyst 2960? If so how?
Correct Answer by Giuseppe Larosa about 7 years 8 months ago
Hello Jamal,
if switchport enc dot1q is not supported it means that C2960 like C2950 supports only dot1q.
Don't worry about this.
as Rick has noted you need the
switchport mode trunk to make the port acts as a trunk
Hope to help
Giuseppe
Correct Answer by Richard Burts about 7 years 8 months ago
Jamal
Yes the other suggestion is to change the interface config from:
switchport mode access
to
Rick
Hello Jamal,
I guess you would like to have multiple vlans on the same port.
This is called a trunk port
example:
int f0/5
switchport
switchport trunk allowed vlan 10,20,30
this puts port fas0/5 in vlans 10,20,30.
be aware that device that connects to this must be able to understand the so called vlan tag and to agree on the list of permitted vlans.
Hope to help
Giuseppe
Overall Rating: 5 (3 ratings)
Correct Answer
Giuseppe Larosa Fri, 09/04/2009 - 09:01
  • Hall of Fame,
    Founding Member
Hello Jamal,
example:
int f0/5
switchport
Hope to help
Giuseppe
jekood001 Mon, 09/14/2009 - 07:05
Hi Giuseppe,
I don't have the "switchport encapsulation dot1q" as a command option.
I still am not able to put a phyical port on two seperate vlans. Here is what the running configuration had for my port.
Int gb 0/5
switchport access vlan 10
switchport trunk allowed 10, 20
I'm not sure how to grant access to vlan 20.
If enter "switchport access to vlan 20" for that port, vlan 10 is no longer on the access list. It almost as if I can only assign one port to only one vlan.
I can't get port 5 to be on both vlan 10 and 20.
Any other suggestions?
Correct Answer
Richard Burts Mon, 09/14/2009 - 07:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jamal
to
Rick
Correct Answer
Giuseppe Larosa Mon, 09/14/2009 - 08:34
  • Hall of Fame,
    Founding Member
Hello Jamal,
Hope to help
Giuseppe
