CUCM 6.1.2 Backup
Sep 4th, 2009
In the backup device menu you can change the "Number of backups to store on Network Directory" by toggling the drop-down box and selecting the number you want. When I try to change it from its current setting of 2 to something else it won't allow me to do so, how do you do that. I'm logged in as the administrator so was wondering if there is a setting somewhere that needs tweaking?
thanks.
kking2008 Fri, 09/04/2009 - 07:36
You're not allowed to change the settings of a backup device that is active in a schedule. You will need to either delete the schedule or re-assign it temporarilily to anothe backup device so that you can alter the backup device in question.
