09-04-2009 06:53 AM - edited 07-03-2021 06:01 PM
Hi guys
I nedd help. Im having a very serious problem on my wireless connection, My laptops could connect when configured, after 2 weeks of laptops can not connect, the only solution is to restart the Router.
currenty im running a c181x-adventerprisek9-mz.124-15.XY3.bin
Hope anyone can help me.
09-10-2009 04:03 PM
Sounds like an IOS bug. Have you tried upgrading?
09-11-2009 12:40 AM
You may be hitting CSCsb90481 Bad enque and Traceback when ping with packets > 1445 bytes
If you are running a newer code than 12.4(05.13)T which you obviously do, then you may be hitting a regression of this bug or a similar one, and you should contact TAC to get this properly analyzed and fixed.
This is a crash involving a traceback and TAC should be contacted, to find the proper root cause. Else you can try other versions, I dont find anything for 12.4-15.XY3.
