Does the Live Record feature work with analog phones?
Sep 4th, 2009
I have a Polycom conference phone that we would like to use the Live Record feature with and do not know if it is supported.  Is there a "hookflash" command summary available for analog devices?
Thanks for your assistance,
Kelly
Marcos Hernandez Fri, 09/04/2009 - 11:09
You should be able to initiate a meet me conference to the Live Record extension using a FAC from an analog phone. You can change the FAC (and use a start code, for example) using this command:
UC500(config)#stcapp feature access-code
UC500(config-stcapp-fac)#?
STCAPP feature access-code configuration commands:
  call               Select call forward all feature
  default            Set a command to its defaults
  meetme-conference  Select meetme conference feature code
  no                 Negate a command or set its defaults
  pickup             Select pickup local group feature
  prefix             Select feature access code prefix
Remember that the FXS ports need to be in SCCP mode.
Marcos
Related Content
