How to install languages for the locale installer
Sep 4th, 2009
How do you install languages to use for the locale installer? I can't seem to find a doc on that. I want to have several languages available in the drop down for user locale. Thanks.
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 09/04/2009 - 09:36
If would REALLY help if you mention what product and version you need help with.
java
d.anthony.hadley_2 Fri, 09/04/2009 - 11:47
I guess I put that up too fast. Thanks for letting me know. It's Unified Communications Manager 6.01.
Jaime Valencia Fri, 09/04/2009 - 12:18
No problem, just remember that no one here is a psychic ;-), always mention product and version.
Software Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_0_1/cucos/iptpch7.html
You can use the Software Upgrades options to perform the following types of installations and upgrades:
•Install/Upgrade-Use this option to upgrade the application software, install Cisco Unified Communications Manager Locale Installers and dial plans, and upload and install device packs, phone firmware loads, and other COP files.
The locale files are all available at the download center. Once you've installed them you will see them as options in drop down menu.
java
if this helps, please rate
