strange mtu problem on site to site vpn
Sep 4th, 2009
I have a strange problem.
I cant send packets between 1400 and 1480 bytes to a remote site connected through a aes-256_sha vpn tunnel. This is causing alot of connection problems.
when i send those packets a see a log entry "No translation group found for icmp src outside:x.x.x.x dst inside: (type 3, code 4)" is my station i send the packets from and x.x.x.x is the outside ip address of the asa. The x.x.x.x address is used the nat all the outgoing connections
I tried the command crypto ipsec fragmentation before-encryption outside but that didn't helped.
Any ideas?
be04376 Fri, 09/04/2009 - 09:21
i just used the command crypto ipsecdf-bit clear and now the packets get trough.
not sure why the asa thinks he can't fragment. I didn't set the dont fragment bit i used ping -s 1400 ( and not the -M do option)
