Apply additional license to 3750-E stack
Sep 4th, 2009
I have one stack with two 3750-E and only one switch with IP advanced services license to run OSPF. The second switch still has its original license (IP base). I got from Cisco a license file for the second switch (ip advanced). I have tried the normal procedure to install the license but it is stil not working. I am getting "xml parsing file" error. We ruled out the possibility of a corrupted file.
Is there any specific procedure to apply this license to the second switch while it is on a stack and running? Do I need to separate the stack to apply the license to the second one?
Why do I want that? - in case one fail the other one can handle the OSPF process (high avalability reasons).
Thank you.
Overall Rating: 4.5 (2 ratings)
MachadoGB Fri, 09/04/2009 - 10:22
Ok - one more detail. Do I need to add the ".lic" for the file name? or - is there any specific extension I need to add to the license file name to complete the installation?
Reza Sharifi Fri, 09/04/2009 - 10:28
  • Cisco Designated VIP,
    2017 LAN
Yes, you need the entire name and lic.
Reza Sharifi Fri, 09/04/2009 - 10:33
    2017 LAN
I had the same exact error message with 3 3750-E switches (not stacked). It took us a long time with TAC, our SE and sales rep to get this resolved (what a pain).
1-try adding a forward "/" after flash
and before you add the .llc file.
The correct syntax on the 3750E is:
#license install flash:/CAT1114R0CO_20090526094501582.lic
(NOTE THE "/")
2-If that does not work, make sure when you download the license key use upper case not lower. For some reasons, if the license in the key file is in lower case, it would not work. Because the actual license on the box is in upper case
Reza
MachadoGB Fri, 09/04/2009 - 11:01
Thank you Reza,
I will try during my next maintenance window 9-13 and will let you know.
I am having the same problem - the case is going from one group to the other and not a clear answer so far.
Thank you.
Machado
