Cisco Unity 4.0 Build 4.0(5) reporting tool
Sep 4th, 2009
I setup a call handler greeting for our mainline. It gives people the option to hit the number of what department they want. Is there a way to tell what number gets hit the most. Some type of log file or anything? Thanks
Rob Huffman Fri, 09/04/2009 - 09:33
Hi Chris,
Have you looked at;
System > Call Handler Traffic
report from the Cisco Unity Administrator.
Cheers!
Rob
Rob Huffman Fri, 09/04/2009 - 09:55
Hi Chris,
No worries.
Unity Administration > Reports > System Reports > Call Handler Traffic
Hope this helps!
Rob
Chris Alvarado Fri, 09/04/2009 - 09:59
Thank You! your awesome. Real quick. Where the heck is the report haha? It said successfully queued.
Rob Huffman Fri, 09/04/2009 - 10:10
Hi Chris,
You are most welcome! The reports should be in;
\\server\CommServer\Reports
Cheers!
Rob
Chris Alvarado Fri, 09/04/2009 - 10:59
Thanks again all is working. However I have had this call handler in place for almost a year now, but it only seems to be giving me a report for the last month. i changed the parameters too.
