CAR
Sep 4th, 2009
Does anyone know whether the "Export CDR/CMR" file will give me all call detail records including caller, called #, date, time, and duration? Also, any idea how long records are kept? CUCM6.1
This is a question from a customer which I can not find in crdadmin.pdf
thanks in advance
Overall Rating: 4 (1 ratings)
Jaime Valencia Fri, 09/04/2009 - 18:04
  • Cisco Employee,
  • Hall of Fame,
    2011
6 months max
From CAR admin guide
In the Min Age of Call Detail Records field, enter the minimum number of days that you want CAR to use when it purges CDRs from the CAR database. Enter a number between 1 and 180. The default value specifies 30 days.
java
if this helps, please rate
cooper_69 Mon, 09/07/2009 - 08:19
HI Java,
It does help, I will rate for sure.
I just want to verify that when you Export CDR/CMR file it will give you all call detail records including caller, called #, date, time, and duration?
Thanks!
