Map mulitple static IP through single 877 router for subnets
admin_2
Level 3
Level 3
Hello All.
I have searched around a bit and I believe the 877 router will do what I want but I would like to have this confirmed.
Here's the situation.
Assume there is a static IP address 201.97.237.216 (not the real IP) for a ADSL service.
The ISP has mapped a block of other static IP's that are directed to 201.97.237.216 address. Assume the block goes from 201.97.229.128 to 201.97.229.135.
I want to hook up a 877 router and configure the wan port to be 201.97.237.216 and then have port one on the lan side connected to a router with the ip address 201.97.229.130. This router will be one subnet or vnet. Port two on the 877 router would be connected to another router with the ip address of 201.97.229.131. This would be a second subnet.
Can the 877 router support this? If I read the specs correctly it looks like it supports vlan's.
Would a web user be able to connect to 201.97.229.130 and be connected to the subnet 1 through port 1 of the 877 router?
Is the web interface intuitive enough to allow this to be configured easily?
If someone knows of a sample config file for this type of connection I would appreciate seeing it.
Thanks for considering this post.
vkapoor5
Level 5
Level 5
Collin Clark
Support for 2 VLANs with Base Image. One VLAN dedicated to DMZ.
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
I've never used the web interface, but this is a pretty straight forward setup so it should be pretty intuitive.
Assign the WAN interface the IP of 201.97.237.216. Assign the LAN or DMZ interface with 201.97.229.x. Then you can assign other hosts in the 201.97.229.x range. They must be in the same VLAN as your inside/DMZ interface.
Hope it helps.
