How add or remove "?" as a word in a router command
Answered Question
Sep 4th, 2009
Hi I have a client router configured with apeer group statement which includes "?" in it.
neighbor Sprint? peer-group
neighbor Sprint? remote-as 0000
neighbor Sprint? description LEVEL
can some one tell me how to get the ? as the charater in the statement .
Ullas
Correct Answer by Jerry Ye about 7 years 9 months ago
Use this key sequence Ctrl+v ? to put the ? as a string.
HTH,
jerry
Overall Rating: 5 (3 ratings)
Correct Answer
Jerry Ye Fri, 09/04/2009 - 13:50
  • Cisco Employee,
HTH,
jerry
Jerry Ye Fri, 09/04/2009 - 13:57
  • Cisco Employee,
You are welcome.
jerry
Mohamed Sobair Fri, 09/04/2009 - 13:57
  • Gold, 750 points or more
Use the (CTRL + V) to add the ? chracter.
Use the no form of the full command to remove it.
Mohamed
