Drops on Tunnel interface
Sep 4th, 2009
I am getting drops on tunnel interface on the router. Tunnel interface and configurations are attached with this email. This is a 5 Mbps link on fiber and the traffic is going not above 2.5 Mbps but still I am getting drops. There are no drops on the physical interface whereas drops are seen on the tunnel interface.
Asim
u1kumar2002 Fri, 09/04/2009 - 23:01
Hi Saad,
If you are facing drops in tunnel interface Plz check the usage. If the usage is more than physical link bandwidth. This could be one reason.
I don't know how to open the attachment i this forum. Can u plz share that how i can see u attachment. So that i can get better understanding. I am new in this forum.I tried but i am not able to see the attachment
waridtel.com Sat, 09/05/2009 - 01:03
The physical interface is FE i.e. 100 Mbps while the traffic is around 2.5 Mbps.
You can open the attachment by clicking the arrow key pointing downwards.
waridtel.com Sat, 09/05/2009 - 03:24
Please help me out with this. I am facing severe issues because of this problem.
Mohamed Sobair Sat, 09/05/2009 - 04:32
  • Gold, 750 points or more
This could be due to IP Fragmentation issue.
I would set it as follows:
1- remove the (IP MTU 1400) command from the tunnel interface.
2- configure (Tunnel path MTU discovery) command on both tunnel interfaces.
3- On the Physical interface try to drop the IP MTU to 1476 as the GRE tunnel would add 20 Byte for the IP header and 4 Byte GRE header.
let us know the result,
Mohamed
waridtel.com Sat, 09/05/2009 - 04:54
Thanks for your reply.
As per your suggestion I should:
1) remove ip mtu 1400 command from tunnel interface
2) configure "tunnel path mtu discovery" on the tunnel interfaces.
3)On the physical interface I should write the command "ip mtu 1476"
Please confirm me. Thanks.
