read text file in Flash
How to read text file flash memory
9 Replies 9
pcameron
Use the 'more' command. Here is a console log showing it in use -
VG202#dir flash:
Directory of flash:/
1 -rw- 18955952 Mar 1 2002 00:19:50 +00:00 vg20x-ipvoice-mz.124-22.T.
bin
128843776 bytes total (109887488 bytes free)
VG202#copy run flash:Myconfig.txt
Destination filename [Myconfig.txt]?
1593 bytes copied in 0.392 secs (4064 bytes/sec)
VG202#dir flash:
2 -rw- 1593 Mar 6 2002 19:28:26 +00:00 Myconfig.txt
bin
128843776 bytes total (109883392 bytes free)
VG202#
VG202#more flash:Myconfig.txt
version 12.4
no service pad
hostname VG202
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
ip source-route
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
stcapp call-control mode feature
voice-card 0
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.66.75.41 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.66.75.1
no ip http server
control-plane
voice-port 0/0
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 0/1
ccm-manager fax protocol cisco
ccm-manager config server 10.66.90.130
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
mgcp fax t38 ecm
sccp ccm 10.66.75.212 identifier 2 version 6.0
sccp ccm 10.66.75.211 identifier 1 version 6.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 1 pots
service stcapp
port 0/0
dial-peer voice 10 pots
shutdown
destination-pattern 10
port 0/1
dial-peer voice 11 pots
shutdown
destination-pattern 11
port 0/0
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
exception data-corruption buffer truncate
end
VG202#
Thanks, if we need to read text file from Falsh, for example I have readme.txt in flash, how to read that text file from flash, please light me on this.
use the more command -
router#more readme.txt
Thanks a lot this i need..
Hi Expert,
I am being trying to run some show commands in my production environment for taking all the show command output periodically. But i am unable to get the command syntax along with the output. For a long list of show commands it is difficult to identify the output.
I am using show version | append ftp://location
also, show version | redirect ftp:location
but the above command only copies the content as i also want the syntax to be included. can you please help me on this.
For example:- Below is the output from output file.
Actual Output:-
09:04:05.788 CST Fri Mar 11 2016
JKN12x01 uptime is 6 years, 39 weeks, 22 hours, 18 minutes
Expected Output:-
JKN12x01#sho clock
JKN12x01#sh version | in uptime
Please assist me in the above query.
Thanks in Advance :)
Jenish Nagoria
Dear all,
Anyone know that how to copy to the current show command into a text file?
Example, copy running-config tftp://192.168.0.1/config.cfg
or
copy flash:xxxx tftp://192.168.0.1/
I have no problem on copy configuration, IOS, etc.
But how to copy the current show run, show inventory, show proc cpu, show tech, into a text file?
Is it we need to create a directory, then issue all this show command, show xxx, show xxx, then capture all this result and save it into text file.
I understand that teraterm or hyper terminal can capture, but i want do it in some script or batch file.
help.
you could use pipe redirect. for example, to save the show vlans output to a file on a tftp server:
show vlans | redirect tftp:192.168.1.1/myvlanoutput.txt
this will work for any standard destination
Teoh Chee Hin
may i know that how to copy the current show command result to text file?
example, "show interface status" or "show environment", "show tech", i want the show result to be save into a text file with windows based workstation
is it just copy "something" to tftp://192.168.1.1/result.txt" something like tht?
I've already answered to your post/thread.
