BLF is not working
Sep 6th, 2009
We are using CCM 6.1, in that BLF is not working.
The following config are done as below:
1) Enable the BLF in Enterprise parameter
2) Clusterwide Sercvice Paramater for Presence group
3) Apply presence group to the directory number.
4) Cuastomize phone button template for the BLF speed dial
5)Configure BLF/Speed dial button fo rthe phones device profiles
6) Add a presence group to the Dn
When I follows the abovwe steps, the device showa BLF speed dial as ordianry speed dial. any suggestion please let know.
Overall Rating: 5 (1 ratings)
acharyr123 Sun, 09/06/2009 - 04:49
Your configuration fine. Kindly do these 2 steps & let me know..I aso have 6.1 & it's working fine.
Under Protocol Specific Configuration (on the Phone):
1. Presence Group*---> Select the bew Presence Group that you created.
2. Subscribe CSS--> Selcet the CSS on which IP phone is residing.
BALAMURUGAN SINGARAM Sun, 09/06/2009 - 04:59
Yes I have updated the two parameter and reset and reboot the CCM also, but the BLF/SD shows like normal speed dial.
Please light me what I am missing in this config.
jquoss001 Tue, 12/06/2016 - 10:55
Try this...
In callmanager goto the Phone Configuration page and scroll down to the box called Protocol Specific Information. In that box is a field called SUBSCRIBE Calling Search Space. That field needs to be populated with an internal network calling search space. This will enable the indicator lights for your BLF entries. I hope this helps. Have a Great Day!
