Extension Mobility feature between differents clusters
tranarison
Dear all,
I'd be gratefull if someone here could give us an idea on how to extend Extension Mobility feature between to different
Cisco Unified CM clusters. May be there is an equivalent featuree ?
Thanks in advance.
Tsiavo.
Rob Huffman
Hi Tsiavo,
The following restrictions apply to Cisco Extension Mobility:
•Cisco Extension Mobility works on phones within a single Cisco Unified Communications Manager cluster only.So you would need to create a profile for the same user on each cluster.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsem.html#wp1055598
Here is a clip from my friend Michael @ Cisco that pertains to this Cross-Cluster EM support.
What used to be Metreos application is now the Cisco Unified Application Environent (CUAE).
CUAE has a cross cluster Extension Mobility application.
http://www.cisco.com/cdc_content_elements/metreos/download/Metreos_ClusterMobility_WhitePaper.pdf
http://www.cisco.com/cdc_content_elements/metreos/products/applications.shtml
http://www.cisco.com/en/US/products/ps7058/tsd_products_support_install_and_upgrade.html
Hope this helps!
Rob
