5508 1142 H-Reap anyone?
Sep 6th, 2009
Does anyone have a 5508 controller with 1142's setup in H-Reap mode with wpa2/aes/psk authentication?
No matter what configuration i try I cannot get a client connected if the access point is communicating with the controller. As soon as I disable/block the access point from communicating with the controller, the client can connect.
Has anyone else come across this problem? Could anyone else verify the same thing I have?
Dan.
didyap Fri, 09/11/2009 - 08:55
An 1142 access point in hybrid-REAP mode sometimes enters stand-alone mode. If the access point is rebooted while in stand-alone mode, the 802.11a radio changes to a different channel than the one configured by the controller after a few minutes.
danletkeman Sat, 09/12/2009 - 08:10
Very odd problem, but after i restarted the controller everything started working as it should.
Dan.
Trending Topics - Security & Network
