NAT overload on asa 5520
Sep 6th, 2009
I have a ASA 5520 and would like to know how to setup NAT overload so my internal users can access the internet with the one public IP I have.
shanemcanuff Sun, 09/06/2009 - 17:34
I try that commands and I was unable to overload, do I need to setup any ACL?
kwillacey Sun, 09/06/2009 - 18:07
You can either nat anything or ur specific subnet
nat (inside) OR
nat (inside)
As long as you have ur nat global ur nat inside
and ur default route it should work
shanemcanuff Mon, 09/07/2009 - 07:42
guess I am missing something cause it did not work for me at all. Can someone look over my config.. plz.. I am using windows 7 and have problems getting to the GUI.
: Saved
ASA Version 7.0(8)
hostname tempasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address
interface GigabitEthernet0/1
nameif dmz
security-level 50
ip address
interface GigabitEthernet0/2
nameif inside
security-level 100
ip address
interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address
ftp mode passive
pager lines 24
logging asdm informational
mtu outside 1500
mtu dmz 1500
mtu inside 1500
mtu management 1500
no failover
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0 0 route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa authentication ssh console LOCAL
http server enable
<--- More --->
http management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address management
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
: end
rlisiecki Mon, 09/07/2009 - 07:58
nat (inside) 1 0 0 route outside 1 (I think this should be two lines)
nat (outside) 1
route outside 1
shanemcanuff Mon, 09/07/2009 - 08:59
should I be able to ping the outside interface from the inside interface?
Kureli Sankar Mon, 09/07/2009 - 09:10
You mean ping the outside interface from an inside host/pc?
No. You can only ping the closest interface to the PC. If the PC is on the inside you can only ping the inside interface IP.
If the PC is outside you can only ping the outside interface IP on the FW.
That is by design.
As far as your nat lines. both nat and route lines appear as one line. I am not sure how that happened. Pls. make sure
sh run nat
only shows the following
nat (inside) 1
and sh run global
These two lines do the overloading that you do in case of routers.
Collin Clark Tue, 09/08/2009 - 05:16
From the ASA can you ping If it fails, do a SHOW ARP and see if you see a MAC to IP mapping. Let us know the results.
shanemcanuff Tue, 09/08/2009 - 06:06
thanks a lot guys I got it to work, I am going to try to pool 3 public IP I have to do NAT overload.
Collin Clark Tue, 09/08/2009 - 06:26
You can only PAT one address. If you use 3 addresses, it will 1:1 NAT the first two addresses and then PAT the 3rd.
shanemcanuff Wed, 09/09/2009 - 13:34
Thanks a lot, I got it to work now. The major problem I was having was that I keep test the ping from the ASA, which keep failing when I test it from a system on the LAN I was able to access the internet.
