switch loads the old code not the new code
Answered Question
Sep 6th, 2009
Problem in upgrading IOS on the Switch. The Stitch is currently has c2950-c3h2s-mz.120-5.3.WC.1.bin code on it but when i try to upgrade the code i copied c2950-i6k2l2q4-mz.121-22.EA13.bin to the flash and issued the command
Switch# boot system flash:c2950-i6k2l2q4-mz.121-22.EA13.bin and restarted the switch
But the switch is loading the old code not the new code
Tks
Logesh
Correct Answer by Peter Paluch about 7 years 10 months ago
Hello Logesh,
If you entered that command indeed as indicated above, then you have entered it in the privileged mode where it is not valid. It should be entered in the global configuration mode, i.e.:
Switch# configure terminal
Switch(config)# boot system flash:c2950-i6k2l2q4-mz.121-22.EA13.bin
Switch(config)# exit
Switch# copy run start
Switch# reload
Best regards,
Peter
Overall Rating: 5 (1 ratings)
Correct Answer
Peter Paluch Sun, 09/06/2009 - 21:29
  • Cisco Employee,
Hello Logesh,
Switch# reload
Best regards,
Peter
