Restrict Access Vlan with WLC 4402
Sep 6th, 2009
Folks, I have three SSID configured on WLC and three groups configured on ACS and I need to restrict SSID access based on ACS group.
I tried to use this guide below.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807669af.shtml
How you can see, this example is aplicable to 802.1x and work out fine with 2 SSIDs that I have but the third SSID don't work because it use the NAC Web login to Auth the user, I needed to fallback because this configuration blocked my NAC Authentication.
Although I have configured NAR just Group2 and Group3, users on Group1 that are Auth with NAC were blocked.
Anyone Know Why this or How can i configure this restriction on WLC and ACS?
thanks a lot
Erick Delgado Wed, 09/09/2009 - 10:05
  • Bronze, 100 points or more
You could be hitting DDTS CSCdu52690.
I will suggest to do an upgrade ACS version 3.0 is old and unsupported.
